2.0" to 1.25" Eyepiece Centering Adapter [SI-EA20-205P]
SI-EA20-205P
$71.95 USD
1 in stock IN STOCK, usually ships within 48h or less directly from our warehouse
Starlight Instruments: The Parallizer™ 2 inch-to-1.25 inch adapter utilizes a patented design that insures parallel alignment with the drawtube axis of optical accesories such as eyepieces, camera adapters, and collimation tools. The Parallizer's unique, patented alignment feature assures that the drawtube and accessory axis will always be dead parallel.
The adapter's non-marring clamp screw is set at 45 degrees, camming the accessory down against the adapter flange when tightened. The Parallizer has zero in-focus loss, and does not require a screw slot to seat fully in a drawtube. It is threaded for 48mm (2”) filters.
About 2.0" to 1.25" Eyepiece Centering Adapter [SI-EA20-205P]
