ZWO ASI120MC Color astronomy camera. 1/3''size 1280x960 @30fps Color USB2.0 [ZWO-ASI120MC]
ZWO-ASI120MC
$169.00 USD
ZWO Optical: ASI120 is a very fast and sensitive USB2.0 camera. Up to 30FPS under 1280X960 full resolution! With a peak QE of 75%, beyond ICX618 and with no FPN (Fixed pattern Noise)! Long time exposure supported up to 1000s.
What’s in the box?
–ZWO ASI120MC Colour 1.2 Mega Pixel Astronomy Camera
–150° Lens Adapter for use as an all-sky camera
–M42-1.25″ nosepiece
–1.25″ IR-cut window
–2 m long USB cable
–2 m long ST4 guider cable
–Driver & Extra Software CD
Warning
The lens can be screwed in too far, result in a scratch on the protect window! Please adjust it very slowly! Don’t turn it beyond the focus at infinity!
Full resolution function of the ASI120 requires full 480mbs USB communication!
Mac OSX may not compatible well. Neither Windows though virtual machine. Windows though Bootcamp is recommended. Or use our ASI120S USB3.0 Cameras which runs well under Mac OSX.
About ZWO ASI120MC Color astronomy camera. 1/3''size 1280x960 @30fps Color USB2.0 [ZWO-ASI120MC]
What’s in the box?
–2 m long USB cable
Warning
  • Width: 28 mm
  • Diameter: 62 mm
  • Sensor Type: CMOS Color - 12 bit
  • Sensor size: 4.8 mm x 3.6 mm
  • Number of pixels: 1280 x 960 pixels
  • Pixel size: 3.75 μm x 3.75 μm
  • Sensor: Aptina Imaging AR0130CS Colors
  • Number of frames per second: Up to 215 frames per second in 320 x 240 pixel resolution
  • Autoguiding: YES
  • Connectivity: USB 2.0
  • Cooling: NO (passive cooling)
  • IR Filter: YES
  • Compatibility: Prism 8, FireCapture
  • Weight: 100 g
  • Flow: 50.8 mm and 31.75 mm (2 "and 1.25") / T2 (M42 x 0.75)
  • USB cable: Length 2 m
  • Minimum exposure time: 0.000064 seconds
  • Maximum exposure time: 16 minutes
  • Computers: Windows XP, Vista, 7 and 8 (32bits / 64bits)
  • Quantum yield: 68%
  • Model: ZWO color camera ASI120MC
