GM 2000 HPS II Monolith Equatorial Mount Head [10M-2020]
10M-2020
$13,970.00 USD
10Micron: German "go to" equatorial mount, monolithic body, exclusive 10Micron HPS technology with absolute axis-encoders and high performances motor drives; payload capacity of 50 Kg (110 lbs).
Evolving perfection. The GM2000HPS mount, now in the new M2 version, is built for the demanding observer using photographic instruments up to a weight of 50kg – 110 lbs (counterweights not included). Movements are driven by two servo brushless motors, with timing belt reduction having zero backlash. Both axes feature a classic worm – wormwheel pairing. The wormwheels are made of bronze (B14), with a diameter of 172mm and 215 teeth, while the worms are made of alloy steel with a diameter of 24mm. The axes themselves are made of 50mm diameter alloy steel, for the maximum rigidity.
The electronics is housed in an independent control box, easily removable. The connections of the mount and keypad feature secutiry lock screws. The mount can be controlled using the included keypad, without connecting an external PC. The keypad is built in order to maintain the maximum readability in all lighting conditions. Both the display and the ergonomic keys, allowing for the use of gloves, feature a red backlight. An heater keeps the display warm for usage below freezing temperature.
The mount can be controlled using the most common software packages by connecting it to a PC with the RS-232 serial port or the Ethernet connection, via the 10micron ASCOM driver or the Meade compatible command protocol. Furthermore, a dedicated software (also included with the mount) can be used to create a “virtual keypad” replicating exactly the functions of the physical keypad. The RS-232 port can also be used to control an external dome. This flexibility makes the GM2000HPS an ideal mount for observatories and remotized observing sites.
The object database contains many star catalogs and deep-sky objects up to the 16th magnitude. Solar system objects can be tracked so that their motion is compensated with respect to the stars. You may load orbital elements of comets, asteroids and artificial satellites into the mount, so that these objects can be tracked directly using the keypad (without any external PC). Pointing is made accurate through the usage of a model containing up to 100 stars, which allows for the correction of the classical polar alignment and conic errors, and also of the most important flexure terms of the optical tube. In this way it is possible to obtain pointing accuracies of the order of 20 arcseconds RMS. The same model can be used in order to obtain the maximum tracking accuracy, compensating also for the atmospheric refraction (depending on the local atmospheric pressure and temperature).
A series of auxiliary functions is provided to help the user for quick aligning the mount to the celestial pole. You may also save and recover the alignment data of different observing sessions. This function is very useful if you have many instruments in different setups, each one requiring different flexure corrections. Tracking through the meridian, a typical problem with german mounts, is solved allowing for tracking for up to 30° past the meridian (configurable), in both directions. In this way any object can be tracked for at least four hours.
The tracking accuracy makes autoguiding not necessary for many uses. The absolute encoders on both axes allows to obtain a typical tracking error below 1 arcsecond.
It is possible to autoguide anyway, using the ST4-compatible port or through the serial/Ethernet connection, with a guide rate configurable from 0.1x to 1x. The guide rate can be automatically corrected for the declination of the target, so that there is no need of recalibrating the autoguide when observing at different declinations. Among the other functions, you will find the electronically-assisted balance and the ability of parking the mount in different user-defined positions.
The Monolith version is perfect for small observatories.
GM 2000 HPS II "Monolith" Equatorial Mount Head  (Standard Package), including:
GM 2000 HPS II Mount – Monolith version with precision absolute axis-encoders control box with onboard-intelligence (Linux-processor),V. 2 – HPS version firmware, stand alone system ( no PC required ) Professional handcontrol unit with graphic display and temperature control Cables, counterweight bar and strong  transport carton-box with shaped foam WiFi option included. The mount is delivered without a tripod or counterweight.
About GM 2000 HPS II Monolith Equatorial Mount Head [10M-2020]
  • GM 2000 HPS II Mount – Monolith version with precision absolute axis-encoders
  • control box with onboard-intelligence (Linux-processor),V. 2 – HPS version firmware, stand alone system ( no PC required )
  • Professional handcontrol unit with graphic display and temperature control
  • Cables, counterweight bar and strong  transport carton-box with shaped foam
  • WiFi option included.
  • The mount is delivered without a tripod or counterweight.
