GP Clamp for X-Guider / M-Zero mount [AV-9MGP001]
2 in stock specialorder Scheduled Delivery: special order items in stock usually ships within 48h or less directly from our Canadian warehouse
The M-zero mount several configurations (operating mode – telescope type) are summarized with accessories: Dual Dec Adapter, Gp Clamp and GP bar 23mm h.
- Two parallel telescopes: 106 mm f/5 refractor weighting about 9 kg and a 60 mm secondary refractor weighting about 3 kg.
In this setup a suitable length secondary tube is mounted on the optional tool. It can be used for autoguiding, for taking simultaneous picture with different FOVs or different filter, etc. In this case the second telescope constitutes an active counterweight allowing the mount to obtain performances that should require much higher loading capacity mounts. Counterweights used 2 kg total.
- Two parallel tubes: 8” f/10 SC weighting about 7 kg and 70 mm secondary refractor weighting about 3 kg:
In this setup the secondary tube is mounted on the optional X-Guider allowing a precise alignment between the two optics.
- with DSLR Camera
installed on the M-zero mount, allowing to perform wide and extrawide field expositions. It can be mounted standalone or in parallel with a telescope. In this case the telescope can be used as guidescope for longer expositions. With this setup a counterweight is not necessary
About GP Clamp for X-Guider / M-Zero mount [AV-9MGP001]
Avalon Instruments: GP Dove Tail Clamp (compatible: Avalon X-Guider and Avalon M-Zero mount), with single clamp screw.
- with DSLR Camera
