Avalon M-Zero with StarGO WIFI + TPOD-90 [AV-1MZR001-TP90]
Portable Astronomy
The new M-Zero has been designed to revolutionize the world of portable astronomy. The unique and innovative design, the light weight and the small dimensions, the greater versatility and higher quality make it the perfect tool for the traveling astronomy.
Several mounts in one
The M-zero is more then one mounts: a Standard Equatorial when used with longer optics, a Single Arm with the great benefit of non requiring meridian flip using compact optics, an Alt-azimuthal mount for visual astronomy and, finally, an excellent time-lapse platform for panoramic photography and video shooting.
Double Telescope Setup
Thanks to the new Dual-DEC system, it is possible to install a second telescope in the opposite side of the declination axis. Considering this capability it is possible to use a great range of optics starting from a small (4-5 kg/8.8-11 lb) refractor up to a double setup with a total weight of 12-13 kg/26.4-28.6 lb, obtaining performances so good to get it over the need of a bigger mount.
Thanks to StarGO GoToControl System the M-Zero can be controlled by smartphone and tablet via Bluetooth or WiFi connection and can be quickly set in the Alt-azimuthal mode for the visual observation with larger telescopes and binocular or to make panoramic pictures or video sequences with time-lapse features.
Zero Maintenance
Transportability
The M-zero can be balanced, in most cases, with less than 1 kg/2.2 lb counterweight due to the possibility of placing the declination arm in different positions relative to the right ascension arm. The M-zero and the T-pod 90, requiring limited room, may be easily arranged inside a medium size carry on case allowing a convenient setup for air traveling astro-amateurs.
Light and Strong
Made entirely from anodized aluminum, worked using 5 axes CNC machines.
The mount weights only 6 kg/13.2 lb and, combined with the new T-Pod 90 tripod, reaches a total weight of 12 kg/26.4 lb.
Technology and Innovation
The top quality manufacturing level, the innovative Fast-Reverse Belt Drive System with zero backlash and the new StarGO GoTo control system allow excellent performance in the photographic use, with guided long exposure images (see our suggested PHD2 guide parameters table), even while using very long focal length telescopes.
THE POLAR ALIGNMENT can be performed by using the polar scope mounted on the RA body that can be rotated (as shown in the picture above) to the upper position for a comfortable adjustment of the Polar Alignment.
Polarscope Support stand provided of scope fixing knobs and dovetail attack with fixing grip knob. Illuminator cap provided of red LED and connection cable to the StarGO. 90° diagonal kit (optional) The kit can be provided with a Losmandy polar scope
In this case the item 1 shall be of the type suitable to the Losmandy scope in which the graduated scale is not provided. Another option that greatly facilitates the polar alignment operations is the special star diagonal.
This optional component allows to perform the observations through the polar scope in a more comfortable position. This option is available for both types of polar scopes.
Optional Losmandy Polarscope kit
Polarscope support included, adapter and Losmandy Polar scope optional
Low Latitudes Kit
The new kit allows to work till to 15° latitude degrees and it is possible to assemble it in only 5 minutes
About Avalon M-Zero with StarGO WIFI + TPOD-90 [AV-1MZR001-TP90]
Avalon Instruments: Avalon Instruments introduces M-zero. The new Equatorial & Alt-Az Single-Arm telescope mount with Fast-Reverse technology!
Portable Astronomy
Zero Maintenance
Transportability
Light and Strong
- Polarscope
- Support stand provided of scope fixing knobs and dovetail attack with fixing grip knob.
- Illuminator cap provided of red LED and connection cable to the StarGO.
- 90° diagonal kit (optional)
Low Latitudes Kit
- Type: Equatorial-Altazimuth Single-Arm mount with Fast-Reverse technology
- Weight: 5,5 Kg
- Capacity: for photographic use: 8 kg • for visual use: 10 kg
- Transmissions: four-step reducer via pulley-tooth belt system on ball bearing, with no plays on the axes
- Tracking error: +/- 5-7 arc seconds, in average
- Construction material: Anodized aluminium, worked out from single blocks with high precision CNC machines
- Motion system: Pulleys made with special glass fiber polymer and high precision tooth belts
- Polar finder: Skywatcher model
- Goto system: Avalon StarGO GOTO System - WIFI
- Tripod: Avalon Metal tripod T-POD 90 (T-90) - Highest quality anodized aluminium materials, H max 90cm (55cm closed) excellent stability with minimal weight 4,5 Kg., dedicated soft carrying bag (M-Zero compatible)..
- Counterweight bar: Not applies, since no counterweights are required
- Counterweight: Not applies, since no counterweights are requie
- Scope plate: Vixen style
- Warranty: 2 years from the purchase date, extended to 5 years for the transmission system
