Avalon Metal tripod T-POD 130 [AV-0TPOD130B]
AV-0TPOD130B
$995.32 USD
2 in stock Special Order Scheduled Delivery: special order items in stock usually ships within 48h or less directly from our Canadian warehouse
Avalon Instruments: Avalon Metal tripod T-POD 130 (T-130) - Highest quality anodized aluminium materials, H max 130cm (95cm closed) excellent stability & minimal weight 8 Kg., soft carrying bag (Linear & M-Uno compatible). Color: Black
The new metal tripods by Avalon Instruments have been designed to revolutionize the world of portable astronomy with both the style and function that Avalon Instruments is known for. Made entirely from anodized aluminum with stainless steel hardware, the low weight and high stability of these tripods make them the ideal companion for travelling observers and Astro-photographers.
The new Avalon T-Pods are available in three sizes and capacity, the T-90 with a 132 pound (60 Kg) capacity, the T-110 & T-130 with a 220 pound (100 Kg) loading capacity. Even with these substantial capacities, the T-90 weighs only 10 pounds (4.5 Kg) and collapses to a diminutive 22 inches (55 cm) only, while extending to a maximum height of 35 inches (90 cm). The model T-110 weighs only 15 pounds (7.0 Kg) and collapses to just 30 inches (75cm) while extending to a maximum height of 46 inches (110cm), while model T-130 weighs only 17 pounds (7.6Kg) and collapses to just 38 inches (85cm) while extending to a maximum height of 51 inches (130cm).
The built-in spreader system allows the tripod to be quickly and easily opened with no loose parts while the double leg locks and included bubble level make it easy to level the tripod and securely lock it in place. The base of the legs can be fitted with ground spikes for soft ground or rubber tips for hard surfaces. In addition, the tripods are equipped with a convenient handle for easy transport.
While conceived for the Avalon M-Uno, Linear and upcoming M-Zero mounts, the T-110 & T-130 models are also compatible with the mounts including the AP Mach-1; SkyWatcher/Orion EQ6/Atlas and AZEQ6/Atlas Pro AZEQ-G, Celestron CGEM, Losmandy G11, Takahashi EM200, Vixen SXV/SXD/SXP/SXD2 and other mounts while the T-90 will be compatible with mounts including the SkyWatcher/Orion EQ-5/HEQ5/Sirius, Celestron CG-5/AVX, Takahashi EM10, Vixen GP/GPD2 and others. Compatibility will be either native or through the use of an available adapter.
The T-90 T-110 & T-130 tripods continue Avalon’s tradition of cutting edge design and top quality performance in portable observing and Astro-imaging systems.
Features summary:
- Easy setup and takedown - Highest quality anodized aluminum and stainless steel materials
- Excellent stability with minimal weight - Easy transport with built-in handles & dedicated soft carrying bags
About Avalon Metal tripod T-POD 130 [AV-0TPOD130B]
Features summary:
  • SKU    AV-0TPOD130B
  • MANUFACTURER    Avalon
  • TYPE    Tripod
  • WEIGHT CAPACITY    100 kg/220 lb
  • LEG LENGTH    39" to 51"
  • LEG TYPE    Tripod
  • WEIGHT OF TRIPOD/MONOPOD    7,6 Kg/17 lb
