ZWO EFWmini (5x1.25') [ZWO-EFW-MINI]
ZWO-EFW-MINI
$199.00 USD
ZWO Optical: The smallest and most lightweight 1.25″ Electronic Filter Wheel in the world! 300g ONLY!
Small than your hand !
The body is CNC machined from a full block of aircraft grade aluminium.
Very thin design, 20mm ONLY
The step motor is the heart of the EFWmini, which is made by NPM from Japan. You can trust its quality and relIability.
Supports both 5*1.25″ filters or 5*31mm filters
The Electronic Filter wheel can be rotated in both counter clockwise or clockwise direction for filter selection.
Only one USB Cable is enough to power up the EFW, the max power consumption is around 120ma@5V, so you can connected it form the USB2.0 hub of our cooled cameras.
The distance between the filter and sensor is aroucnd 10mm when you connect it to ASI1600.
So 1.25″ filters won’t have vignetting up to F5 focal ratio scope and 31mm filter won’t have vigentting up to F2 lens
Our new RGBL filters are recommended to work with ASI1600, it will offer nearly 1:1:1 RGB color balance.
The full EFW mini Set includes:
EFW mini body, T2 nosepiece, 1.25″ Holder-T2, T2-T2, USB2.0 Cable
1.25″ filter requires: threads length shorter than 3mm, height without threads less than 7mm
31mm filter requires: a set of M2 screws and washers needed to fix the filters are included in the package .
How to use it?
you juse need to plugin the EFW mini with USB2.0 cable and install the   ASCOM driver
There are  ZWO Filter Wheel(1) and ZWO Filter Wheel(2) to select,  you can use either one of them
There are 2 ASCOM is for controling 2 EFWmini in one software.
About ZWO EFWmini (5x1.25') [ZWO-EFW-MINI]
How to use it?
  • Depth: 20 mm
  • Diameter: 115 mm
  • Connectivity: USB 2.0
  • Weight: 300 g
  • Power Supply: USB 2.0
  • Model: Filter wheel ZWO EFWmini 5 x 31 mm not mounted
  • BackFocus: 10 mm
  • Diameter of the filters: 31 mm
  • Number of possible filters: 5
  • Comes with: 31.75mm and 50.8mm (1.25 "and 2") adapters, T2-T2 ring, USB 2.0 cable
  • Power Consumption: 120mA - 5V
