Mike
Due to a cloudy night I'm capturing darks. I'm using my 60 Da and capturing 900 second frames. I noticed that the first frame, with the camera just turned on, the sensor temperature was 72 degrees F. Over the next 900 seconds the temperature remained reasonably the constant, yet the sensor temperature was recorded at 82 F. The images were captured at the same exposure duration, but there is a 10 degree difference in sensor readings. The third frame was 2 degrees warmer though the following frames have stabilized. This makes me wonder when the temperature is recorded, at the start or the end of the exposure. It seems to me that with a constant ambient temperature the sensor temperature at the end of each exposure of the same duration would be the same. So is the temperature recorded at the start or the end of the exposure? If it's recorded at the start is it possible to change that to record the temperature at the end, or is that a SDK issue?
3 answers to this question
