kwatson
When initially connecting the camera in BYE, the aperture/av does not display in the Camera Info Center and is not available to set in the Capture Plan Center.
Found a workaround, which is to connect the camera, take an image in BYE, and then disconnect & connect the camera in BYE. The aperture/av displays correctly. Screenshots showing this behaviour are below, and BYE logfiles attached.
Is there a fix I can make so that the aperture displays correctly the first time?
Thanks! Kevin.
Details:
BYE version: 3.2.1.39956
Camera: Canon 6d
Lens: 200mm f/2.8
BYE logs: attached (1-corresponding to initial Connect; 2-corresponding to 2nd Connect after workaround)
1. Start BYE & Connect camera - aperture missing
2. Capture Image - after capturing an image, Av displays in Info, and Aperture column in Capture (however is blank and dropdown is blank)
3. Disconnect & Connect Camera - Displays correctly in both centers
1st_ Unsuccesful.txt 2nd_Successful.txt
Dec 1
5
Dec 2
Dec 5
kwatson 4 posts
admin 2 posts
astroman133 1 post
Dec 1 2021
Dec 2 2021
1 post
Dec 5 2021
1 post
kwatson
Thanks again Admin and astroman133 for the assistance. We had the camera checked at the remote site and I was mistaken -- it was set incorrectly to P mode, and changing programatically while in use. W
6 answers to this question
