eebclee
BackyardEOS 3.2.2, Canon 80D. I generally have the camera set up with mirror lockup, long exposure noise correction (in camera dark subtraction), ISO 200, 15 second exposures, 5 sec mirror delay. That or a series of short exposures with varying exposure times that don't use LENC, particularly if I'm trying a series of exposures on the moon for instance. BackyardEOS randomly hangs up when it gets to "BUSY" while the camera is taking a dark or saving the image to the card -- it's waiting on the camera forever. I have to quit the application and start over. I've never successfully completed a series of varying exposures because of this. Last night I set up a series of 80 x 15 sec exposures and in three tries never got all 80, 38 total so on average it was hanging after ~12 or fewer frames. If I do series of short exposures it doesn't get more than 2-6 frames in before hanging up. If I set up a single exposure and set it to loop though, it usually works fine, I can let it run for hours.
I had been connecting to the camera wirelessly, and thought that might be the problem, so I'm not connected via USB cable. Unfortunately that hasn't changed anything. I also tried a second cable.
Suggestions? Is there some timeout I can adjust? Any idea why it would behave differently in loop vs. a set number of exposures?
Thanks.
Jul 21
Jul 22
Jul 23
admin 1 post
astroman133 3 posts
eebclee 4 posts
Jul 21 2021
Jul 22 2021
Jul 23 2021
astroman133
Inconsistent symptoms does not seem to be a software issue. I would look at cabling and connections. Let us know how it goes.
7 answers to this question
