rtemen
I need to take many very fast exposures.
It is suggested that the problem I am having with my flats is that there might be mirror mechanism shaking or timing.
It suggested that I set a mirror lock-up for a second or two before the shot to see if that settles the problem down.
Here is what is happening with my process:
1. I enable mirror lock-up on my camera
2. I set the mirror lock-up to one second
3. I hit Start Capture
4. In 30 to 45 seconds the mirror goes up
5. In another 30 to 45 seconds, it sounds like the camera takes the shot
6. In 59 seconds, I get an error message that the download has timed out
7. At this point the progress clock at the top right keeps spinning and BYE is locked up and I have to kill it because after many minutes it will not respond
8. I even try Aborting, and nothing will wake it up.
Any suggestions?
Rich
14
Feb 4
16
Feb 5
9
Feb 3
6
Feb 21
rtemen 17 posts
astroman133 14 posts
admin 2 posts
s3igell 2 posts
Feb 4 2021
Feb 5 2021
Feb 3 2021
Feb 21 2021
astroman133
How do your flats look, as far as the dark band and the histogram? I would not use the BYE histogram as this is based on the JPG that embedded in the RAW and as such has an auto-stretch applied. Look
astroman133
I am not sure where you heard that the pixel values for flat frames should be 7-8K. Here is what I have heard: An ideal flat frame histogram would have a peak at about the 50-60% level and have a
35 answers to this question
