griwei
Hi.
I experienced much difficulty with Backyard Nikon and my D850 and my D800E last night. Both were connected to the Windows 10 Pro Microsoft Surface Pro (7th gen) using the Tether Tools USB system.
Although I was always able to connect the D800E, as soon as I switched to the find & focus feature, the connection was dropped and the camera showed an ERR message. When I tried preview, I was informed that I couldn't use the BULB setting. Fine, I switched it, but then on the next attempt the camera disconnects and turns back on in BULB.
Eventually, I tried out the D850. The first four times didn't work and each was accompanied by a scratchy electrical sound emanating from the USB connection. The fifth and subsequent attempts worked fine (and with no scary electrical noise). I was able to use the find & focus feature with the D850, although when I attempted to do an image run, I always received the fail beep.
As far as the D850 is concerned, I'm probably just doing something wrong with the settings. If you have some quick suggestions for me on that, thanks.
As far as the D800E is concerned, that's the reason for my appending the log. It seems like a more significant issue.
Thanks for any advice/assistance that anyone can provide.
Log follows:
_______________________________
00:18:23 Licensed to griwei
00:18:23 BackyardNIKON 2.0.11 Premium Edition
00:19:32 Attempting to connect camera...
00:19:32 Nikon/D800e drivers initialized.
00:19:35 D800E CONNECTED!
00:19:44 Unable to set ImageQuality, current setting is assumed!
00:19:45 Camera SHUTDOWN!
00:19:55 Attempting to connect camera...
00:19:56 Nikon/D800e drivers initialized.
00:19:58 D800E CONNECTED!
00:22:13 Imaging session started.
00:23:31 Imaging session cancelled
00:23:31 Image download timeout, process terminated after 59 seconds
00:23:36 Camera SHUTDOWN!
00:23:42 Attempting to connect camera...
00:23:42 Nikon/D800e drivers initialized.
00:23:44 D800E CONNECTED!
00:23:52 Imaging session started.
00:23:58 Imaging session completed successfully
00:24:10 PREVIEW_20200918-00h23m53s705ms.JPG
00:24:23 Unable to set ImageQuality, current setting is assumed!
00:24:23 Camera SHUTDOWN!
00:24:24 Camera SHUTDOWN!
00:24:35 Attempting to connect camera...
00:24:35 Nikon/D800e drivers initialized.
00:24:38 D800E CONNECTED!
00:24:47 Live view is not possible in BULB mode. Please select a different shutter speed.
00:28:12 Live view is not possible in BULB mode. Please select a different shutter speed.
00:28:35 Live view is not possible in BULB mode. Please select a different shutter speed.
00:28:56 NIKON SDK ERROR: [kNkMAIDResult_CameraNotFound] (kNkMAIDCommand_Async, 0, kNkMAIDDataType_Null, 0)
00:28:57 Camera SHUTDOWN!
00:37:59 Attempting to connect camera...
00:37:59 Nikon/D800e drivers initialized.
00:38:02 D800E CONNECTED!
00:38:25 Unable to set ImageQuality, current setting is assumed!
00:38:25 Camera SHUTDOWN!
00:38:26 Camera SHUTDOWN!
00:38:39 Attempting to connect camera...
00:38:39 Nikon/D800e drivers initialized.
00:38:42 D800E CONNECTED!
00:38:46 Live view is not possible in BULB mode. Please select a different shutter speed.
00:39:35 Live view is not possible in BULB mode. Please select a different shutter speed.
00:40:00 NIKON SDK ERROR: [kNkMAIDResult_CameraNotFound] (kNkMAIDCommand_Async, 0, kNkMAIDDataType_Null, 0)
00:40:00 Camera SHUTDOWN!
00:40:17 Attempting to connect camera...
00:40:18 Nikon/D800e drivers initialized.
00:40:20 D800E CONNECTED!
00:40:26 Unable to set ImageQuality, current setting is assumed!
00:40:27 Camera SHUTDOWN!
00:40:28 Camera SHUTDOWN!
00:40:41 Attempting to connect camera...
00:40:42 Nikon/D300s drivers initialized.
00:40:49 Camera Not Found! Make sure it's connected to the PC and turned ON
00:41:03 Attempting to connect camera...
00:41:03 Nikon/D800e drivers initialized.
00:41:06 D800E CONNECTED!
00:41:16 NIKON SDK ERROR: [kNkMAIDResult_CameraNotFound] (kNkMAIDCommand_Async, 0, kNkMAIDDataType_Null, 0)
00:41:16 Camera SHUTDOWN!
00:41:31 Attempting to connect camera...
00:41:31 Nikon/D800e drivers initialized.
00:41:33 D800E CONNECTED!
00:41:41 Unable to set ImageQuality, current setting is assumed!
00:41:41 Camera SHUTDOWN!
00:41:42 Camera SHUTDOWN!
00:41:50 Attempting to connect camera...
00:41:51 Nikon/D800e drivers initialized.
00:41:53 D800E CONNECTED!
00:41:56 Live view is not possible in BULB mode. Please select a different shutter speed.
00:42:05 Live view is not possible in BULB mode. Please select a different shutter speed.
00:42:18 NIKON SDK ERROR: [kNkMAIDResult_CameraNotFound] (kNkMAIDCommand_Async, 0, kNkMAIDDataType_Null, 0)
00:42:18 Camera SHUTDOWN!
00:42:40 Attempting to connect camera...
00:42:41 Nikon/D800e drivers initialized.
00:42:43 D800E CONNECTED!
00:42:48 Imaging session started.
00:42:51 Imaging session cancelled
00:42:51 [kNkMAIDResult_OutOfFocus] (kNkMAIDCommand_CapStart, 17, kNkMAIDDataType_Null, 0)
00:42:53 Imaging session cancelled
00:42:57 Imaging session started.
00:43:01 Imaging session cancelled
00:43:01 [kNkMAIDResult_OutOfFocus] (kNkMAIDCommand_CapStart, 17, kNkMAIDDataType_Null, 0)
00:43:02 Imaging session cancelled
00:43:15 Unable to set ImageQuality, current setting is assumed!
00:43:16 Camera SHUTDOWN!
00:43:31 Attempting to connect camera...
00:43:32 Nikon/D800e drivers initialized.
00:43:34 D800E CONNECTED!
00:43:41 Unable to set ImageQuality, current setting is assumed!
00:43:42 Camera SHUTDOWN!
00:43:43 Camera SHUTDOWN!
00:45:02 Attempting to connect camera...
00:45:03 Nikon/D850 drivers initialized.
00:45:10 Camera Not Found! Make sure it's connected to the PC and turned ON
00:45:38 Attempting to connect camera...
00:45:39 Nikon/D850 drivers initialized.
00:45:46 Camera Not Found! Make sure it's connected to the PC and turned ON
00:46:21 Attempting to connect camera...
00:46:22 Nikon/D850 drivers initialized.
00:46:29 Camera Not Found! Make sure it's connected to the PC and turned ON
00:47:22 Attempting to connect camera...
00:47:23 Nikon/D850 drivers initialized.
00:47:30 Camera Not Found! Make sure it's connected to the PC and turned ON
00:48:04 Attempting to connect camera...
00:48:04 Nikon/D800e drivers initialized.
00:48:06 D800E CONNECTED!
00:48:12 Imaging session started.
00:48:14 Imaging session cancelled
00:48:14 [kNkMAIDResult_NotSupported] (kNkMAIDCommand_CapSet, 33042, kNkMAIDDataType_EnumPtr, 318697448)
00:48:15 Imaging session cancelled
00:48:32 Imaging session started.
00:48:33 Imaging session cancelled
00:48:33 [kNkMAIDResult_NotSupported] (kNkMAIDCommand_CapSet, 33042, kNkMAIDDataType_EnumPtr, 318697448)
00:48:34 Imaging session cancelled
Sep 18
6
admin 2 posts
astroman133 2 posts
griwei 2 posts
Sep 18 2020
5 answers to this question
