Andante_2
Hello,
This question refers to a D5600 body and BYN v2.1.0 using Planetary Mode and 5x Live View.
When recording using 5x Live View, BYN and my computer (2018 Apple Air, dual boot w/Windows 10, Thunderbolt port) are downloading frames at a rate of ~100 fps, actually 91.8 fps or some such. This is indeed what is recorded within the *.avi file, EXCLUSIVE OF THE SHUTTER SETTING. For example, a 600 frame collection at 1/10 s integration time should require 60s of clock time plus a bit of additional time for downloading each subframe window. However, the actual collection is complete in ~ 600 frames / 100 fps = 6s! I can only conclude that Live View is being sampled at ~100 fps regardless of the shutter time. This means the same actual frame (which is integrating over 1/10th s) is being displayed by Live View and captured into *.jpg files (which are subsequently compiled into an *.avi movie) multiple times per actual camera integration (i.e., shutter "open") interval.
Some background follows.... The iso level appears to be properly set within BYN because the planetary image brightens or darkens as appropriate within the Live View window of BYN. The same is true for the shutter time setting: increase the shutter time and the Live View image brightens, as it should. Take my previous example: if BYN is sampling the Live View stream at, say, 100 fps (or directly reading it out at that rate), I am essentially collecting 10 of the same images for each 1/10th s exposure. I obviously want to know how to collect a single Live View frame per camera integration time.
For what it is worth, and this may not be relevant: the download rate of ~100 fps is the same whether or not I turn the manual movie mode "on" or "off" in the BYN settings block. The difference here is that, with manual "off," the camera seems to set it's own iso and shutter speed, and the images are often overexposed. So ... I turn manual "on."
Thank you in advance,
Don
Aug 23
Sep 16
Sep 17
Sep 3
admin 2 posts
s3igell 2 posts
astroman133 4 posts
Andante_2 6 posts
Aug 23 2021
Sep 16 2020
Sep 17 2020
Sep 3 2021
13 answers to this question
