YOURJONES
Hi
QUESTION 1
I tried the planetary video with my Nikon D5600. I got a frame rate of about 94 FPS. Does this mean the 60 FPS from the camera's own setting options is only theoretical, and that the actual rate can be high as 94 when the frame resolution is reduced to LV size?
QUESTION 2
The same system as above. I can adjust the ISO when filming in the planetary mode, but seems that the "shutter" setting does not work the way you want it to. The BYN wants to achieve high framrate regardless of your shutter setting. Is this the case?
Thanks
May 24
7
admin 2 posts
astroman133 2 posts
YOURJONES 2 posts
s3igell 1 post
May 24 2020
astroman133
BYN does not use the camera's movie mode, so the camera's movie frame rate is not applicable to BYN. BYN's frame rate is the rate at which it downloads LiveView images. This has to do with the sp
admin
IT is not BYN that controls the frame rate, it is the camera. The way LV works is that the camera makes a LV frame available one after the other, as fast as it can. BYN listen to the image ready
s3igell
This is a very respectable Frame Rate for a Dedicated Planetary Astro Camera. It is a GREAT Frame Rate for a Tethered DSLR (and is likely limited by the Camera's USB2 Port ). It is definitely mo
6 answers to this question
