Andante_2
Hello,
I just purchased Backyard Nikon in order to take astrophotos with my Nikon D5500.
(1) The camera: This is a used camera body I purchased, and then removed the IR filter myself. The camera itself appears to work fine: the screen, the shutter, etc. I reset the Reset Shutter Settings and reset the Reset Custom Settings. I then selected ISO 800, manual control, and "Bulb" shutter setting. I selected RAW images (no jpeg). I verified that "WiFi" is OFF. The camera still works fine after these changes. However, I note that when the camera is connected via USB to the computer that the shutter "freezes." It unfreezes when I disconnect the USB cable,
(2) The computer: I have an iMac Air with a dual-boot Windows 10 system running on BootCamp. There are two USB-C ports, and I use adapters to connect this up either to USB 2.0 or USB 3.0 devices. One of the USB ports is presently connected to a USB Hub using a USB-C to USB 2.0/3.0 adapter, and I can see my ZWO ASI120MM just fine in the "devices" list in Device Manager. This guide camera also works fine on the screen using either port,
(3) D5500-to-USB connection. I connected the D5500 directly (no hub) to the remaining USB-C port on the iMac. I used a 4' cable and the aforementioned USB-C to USB 2.0/3.0 adapter. I switched the USB-C connections (the hub works just fine on either port) and ... still no appearance of the D5500 in the "devices" list. I tried wiggling the USB cable on both ends and ... nada.
So far then:
(1) the camera appears to be working on its own,
(2) both USB-C hubs on the iMac/Windows 10 computer are working,
(3) wiggling the USB cable gently at the Nikon connector has no effect
BUT ... using Device Manager I do not see the D5500 anywhere.
... help!
Thanks,
Don
Dec 8
admin 1 post
s3igell 1 post
Andante_2 2 posts
Dec 8 2019
3 answers to this question
