ouioui01
Hello,
A friend of mine gives me a Nikon D800 (with last firmware from Nikon). I can connect it to BYN with no problem. The only problem i have with it is that i can't use BYN to shoot and save pictures:
1. Light / Dark / Flats / Bias :
· save to Camera: KO
· save to PC: OK
· save to PC+Camera: camera OK, PC not OK (picture is in download folder of BackyardTEMP folder).
2. Preview: ok
I configure my setting folders like that
- Download folder: D:\BackyardNIKON
Sub-folders: LIBRARY
- Plan folder: D:\BackyardNIKON\Plans
- Backyard folder: D:\BackyardTEMP
of course, I delete default folders in my pictures folder.
When I launch BYN, it creates again a log file in : D:\Users\myuser\Pictures\ BackyardTEMP\Logs:
Logfile-[timestamp]-backgroundworker- [xxxx]-YYYY-MM-DD
In D:\BackyardTEMP\Logs, I find an another file logfile-[timestamp]-[xxxxx]-YYYY-MM-DD
Do I miss something?
Thanks for your answer and your help.
Bests regards,
Ouioui01
NB: With Nikon software (camera control pro2), i can shoot and save to camera directly from the software
Logs-BYN.zip
30
Dec 6
11
Jan 26
10
Oct 30
8
Dec 4
7
admin 19 posts
s3igell 3 posts
astroman133 17 posts
ouioui01 30 posts
Dec 6 2019
Jan 26 2020
Oct 30 2019
Dec 4 2019
astroman133
Does BYN fail the same way when you save your images to the PC? I believe that there are some BYN issues when saving to the camera. Or perhaps I am mis-remembering and it is with saving both RAW &
astroman133
>> BYN TEMP folder don't change place even i change it in settings...probably due to nikon sdk too. No, the SDK helps BYN control the camera, but the TEMP folder is outside if the SDK...It
68 answers to this question
