KevW
Got BYN up and running last night with my D7000. Love the frame/focus feature!! Waiting for my DSUSB cable to arrive but I'm realizing I'll soon run out of usb ports. Found out quickly that BYN doesn't like a hub...so I ran straight in and it worked no problem. The issue for me is the 'no hub' deal. PHD2 doesn't like to see my asi224 on a hub..took it off....BYN needs a port , so I'll only have one left (out of 3) DSUSB will need one and my handset one also. I'm hoping the DSUSB cable and the handset can run on a hub taken from my last free port on the computer. Any chance BYN will ever play nice with a hub or is it an issue that is likely to remain?
Thanks in advance,
Kevin W.
5
Oct 18
8
Oct 28
5
Oct 27
Jan 28
KevW 9 posts
astroman133 5 posts
admin 2 posts
s3igell 1 post
Oct 18 2019
Oct 28 2019
Oct 27 2019
Jan 28 2020
1 post
astroman133
Kevin, The problem with using a hub with your Nikon camera occurs in the Nikon SDK's communication with the camera. Since BYN relies on the SDK, this means that BYN is at the mercy of the limitat
admin
BYN doesn't care if you use a hub or not; but the Nikon SDK might. The key is the amount of data being transferred and any given time. If you plug your camera in a hub along with other devices t
admin
Does you laptop have usb ports on both sides? If there is, it is very likely that usb ports on each side have separate host usb bus inside your computer. Make sure you don't connect both cameras
16 answers to this question
