t6aphp3
My normal shutdown procedure is
1. In BYEOS, click "disconnect" from the camera.
2. Turn off camera
3. Disconnect the USB cable.
Recently, I noticed my battery still showed 100% charge on the back of the camera, and then I shutdown using step 1, step 3, and then step 2.
Overnight, my camera battery totally discharged.
Doing things in the normal 1, 2, 3 order since, and the battery holds its charge nicely 2 days and counting.
Does the 1, 3, 2 shutdown order explain the dead battery?
What is the correct shutdown order?
Or is it likely my battery is just showing its age?
Thanks!
Steve
Sep 4
admin 1 post
t6aphp3 1 post
Sep 4 2019
