Alfredo Beltran
Hi everyone
I want to share with you this image in Hubble pallete (Red SII, Green Ha and Blue OIII) of the Pelican Nebula.
Captured with Backyard EOS and processed in PixInsight. It was taken with a Baader Modified Canon T1i DSLR and a hyperstar at f2.3 on a C925 EdgeHD. Mount is an iOptron iEQ45.
For this image I extracted the Red channel in the Ha and SII RAW images and the Green channel in the OIII RAW images. Then I did the same for the Red channel or Green of the bias, dark and flat frames in order to produce the master red (or green) dark, flat or bias. The mentioned channel of the RAW files were calibrated with these masters.
This procedure produced a very clean (for a DSLR) Ha, OIII and SII images. Then those monochrome images were combined using the Hubble Pallete R (SII), G (Ha), B (OIII). After that, the image was processed using the usual work flow.
This processing gave much better results than debayering the RAW files in the usual way and after that extracting the desired channel. I think it is because it didn't average the channels that don't receive signal with the ones that do.
Here it is also the version in HaRGB:
Best regards,
Alfredo
Bogotá, Colombia
0 answers to this question
