aamiet
Hi there, I'm starting to run into problems when using BackyardEOS 3.1.17.27056 on my Windows 10 computer with my Canon 700D when using planetary mode. I have found that after recording around 30,000 to 40,000 frames BYE appears to have memory problems and I'm losing data. Sometimes this is recoverable from the temp folder, sometimes not. Restarting BYE fixes the problem, but I need to set up my imaging parameters again, not a huge issue, but a bit annoying.
My workflow consists of taking 2500 frames at a time in 4 loops to give me my 10,000 frames. I save the data as jpgs as it takes too long to save to avi. The first 10,000 run smoothly, the 2nd is usually good also, but by the 3rd or 4th time through I am starting to get the error below and collection stops.
Collection was modified after the enumerator was instantiated.
I realise I'm running BYE pretty hard, but my images are coming out well with this workflow. Is there anything I'm doing wrong here? Any way to flush the memory (or whatever) to fix this issue? I have attached the log file if you need it.
Thanks,
Andrew
logfile-[20190621-19h32m57s651]-[22904]-2019-06-21.txt
10
Jun 21
11
Jun 22
8
Jun 28
Jul 7
aamiet 12 posts
admin 10 posts
astroman133 2 posts
Jun 21 2019
Jun 22 2019
Jun 28 2019
Jul 7 2019
1 post
aamiet
It’s working well now, thanks for the update. Andrew
23 answers to this question
