fjhdavid
hi,
I use a lot liveview for planetary imaging; I use loop but I discovered that even if you disable the automatic shutdown, liveview can't be used more than 30 minutes even if you are recording; (It is true at least for the eos 500d, eos 550d, eos 600d...I checked these three manuals)
The problem is that when the mirror is released, you have to manually shut off/on the camera, otherwise Backyard is locked (even if you restart the computer);
I don't know if it is possible, but maybe a solution could be that the software (in planetary mode) process an automatic liveview on/off every 29mn? then you shoud be able to use the planetary mode as long as you want?
regards
Francois
16 answers to this question
