curlynerd
I had to change from T7i to 7D, hopefully temporarily. The 7D will connect, do Frame and Focus, However, it will not Image . Setting is bulb in BYEOS and M on camera, When I start a capture, it starts, but never stops nor will it abort. It will do preview, but no image is shown or saved. I'm using the USB cable that came with the camera (actually the existing working one on the OTA first) but am getting a message that I need a serial cable as well. I see no connection (like on the 350D) for a serial cable. CameraUSB is selected .Capture works fine with EOS Utility
Any help is appreciated.
BinaryRivers.BackyardEOS.Start.Camera1.exe.user.config
logfile-[20190126-00h29m01s822]-[13448]-2019-01-26.txt
Jan 26
Jan 27
admin 2 posts
astroman133 1 post
curlynerd 2 posts
Jan 26 2019
Jan 27 2019
astroman133
Don't try to use mirror lockup with Bulb exposures. It is not necessary. Leave the Mirror lock setting at 0, disable Virtual Mirror Lock in the Advanced Settings and select Camera USB from the Cable S
curlynerd
Hi guys and thanks for the great responses. It turns out that there were 2 issues. First, with this camera being older than the T7i, I should have moved to bulb setting instead of manual. In addition,
admin
Glad you got it to work.
