jspratt
Hi there,
I've purchased a DSUSB cable from shoestring astronomy. Using the DSUSBchecker app it seems to connect to my laptop fine, however on BYN I can't connect whatsoever. I was using the old 1.0 version with no luck and downloaded BYN 2.0 with no change. I tried with my standard USB cable and it managed to eventually connect after a number of attempts and restarts. This problem seems to happen each time I try to connect my d5100 to BYN, it always struggles to connect at first and takes a number of goes or restarts of my laptop to connect. However with the DSUSB it doesn't look like it's happen at all.
Do you know if this is a common problem, and what the solution might be?
Cheers,
Jonathan
5 answers to this question
