vbagwell
Howdy gang!
When using BYN with the 810a and The SkyX to run a T-Point model (or just take an image), the downloads are c-razy slow. I'm taking an 8 or 10 second exposure in T-Point but the actual time to download is just shy of 6 minutes. Once it downloads, the plate solve occurs within a few seconds and its slewing off to the next point in the model. The pointing samples are added fine and I'm completing the model...just very slowly.
I'm running BYN in a Win7 VM (Parallels 13) on a rMBP. The camera is directly connected to the MacBook with a 15' USB3 cable and I have Renesys USB 3.0 drivers. No disconnect issues but occasionally when starting BYN, I have issues connecting to the camera that always clear with a reboot of the VM.
I'm just curious if anyone else is running BYN with SkyX and the 810a - and if the download times I describe are normal. I have a spare Samsung laptop running Win 7 that I could add SkyX and BYN to test separately to see if this is just a wonky feature of the VM and USB on the MacBook. I may try a shorter cable, but I kinda need a longer cable that can swing with the refractor - although I might be able shorten things with a USB3 hub directly below the Paramount on the pier.
Thanks for your time!
-Vance
Jul 29
6
Jul 31
admin 1 post
astroman133 2 posts
vbagwell 4 posts
Jul 29 2018
Jul 31 2018
1 post
astroman133
I believe that the amount Guylain pays for web hosting this content increases according to the size of the site. He discourages uploading log files by attaching them to posts. You should delete a
6 answers to this question
