vbagwell
Nikon 810a with BYN 2.0.9. Latest Nikon firmware version C = 1.03. The 810a release mode dial is set to S - single frame, and exposure mode is set to Manual, Bulb. BYN is set to Imaging mode. I can connect fine...tried two different USB cables. In the capture center, I have (5) five 1-sec exposures, set to Bulb, with a 5 sec pause. BYN takes the first image, then aborts. Log file attached.
Administrator, noted starting new thread. Per BYN pdf docs, Getting Started, Powering Up... page 18; instructions state to set the release mode dial to S (single shot). ***Note: this should not be confused with the Mup on the dial which is for mirror up. Exposure mode is set to M, with shutter speed set to bulb on the camera. Capture Plan settings: frame type = LIGHT, Cable Support = Camera USB, Save To = PC, Mirror Lock = 0, Delay = 0, Exposures = 5, Shutter = Bulb, Aperture = 5.6, Duration = 1 sec, ISO 200, Pause = 5.
logfile-[20180701-16h15m36s342]-[4208]-2018-07-01.txt
18 answers to this question
