SKYGZR
Cam has worked just fine till this. Last time used, OK. Cam hasen't left the scope, no fiddling with it since last use.
Start BYEOS, fine. Turn on Cam, little message pop's up--normal (This is on XP), Cancel that, Connect BYEOS to
Cam, OK. Frame & Focus window to take a 10s, 12,800iso snap shot, Select, starts, then stops-takes almost the full
10s shot, Not OK. (Think that when D/L image to screen, is when it does the following, and Main
Window reverts back to the connect cam/starting screen, the pop-up comes up again. Try again, same result. Turn Off Cam, unplug (from the
powered hub) the USB cable, plug into another port. Try again, same issue.
Perplexed? Hints to try to resolve?
I do have another T1i that I will try later, yet this seems a bit "weird"...
I can upload the log file later.
36 answers to this question
