Problem with saving/loading a Capture Plan
Ron Hillstromb
Hello All
  I have been making capture plans for the upcoming Eclipse.  I made one today for imaging the post Totality partial eclipse.  I made it for 16 exposures in AV with F8, ISO 200 and a 295 second delay between exposures.  Then after C4 I have a line for 2 exposures with the same parameters and 0 delay between exposures.
  When I save it both lines shows 295 second delay right after i click on Save or save as.  I looked at the .txt file in the plans folder and it looks like the plan I entered 16 with 295 delay and 2 with 0 delay or actually nothing following the ISO  in the second or last line as it is.  When I load it both lines have the 295 second delay in them.
When I run the plan both lines use the delay.  The plan runs as intened if I set the delay to 0 after I load it
  I did some troubleshooting and found that the 295 second delay is added to every line following the line with a delay entered when I click the number of exposures for the line.
  My pre totality plan has the first line set correctly to 0 delay and the second line with the 16 exposures has the delay.
  My totality plan does not have any delays and has worked as laid out.
  It appears that there is a small bug in the plan save and load.
  Sorry to have to report it but better if it is a bug.  it could be something I am doing too.  I don't know what I may have doe to cause this action though.
Any help appreciated.
Ron
  • Answers 7
7 answers to this question
Sorry, Version 3.1.12 when I found this.  Since the post I also found the same ting in 3.1.11 and in 3.1.6.  I removed all other versions I had installed after setting up 3.1.12
  I found it first on a Surface Pro 3 (Win 10 upgrade) with I7 and came to the desktop looking for a earlier version where I found the problem in 3.1.6 also.  It is a Lenovo I5 (Win 10 native).
  As I said above it goes back to 3.1.6 at least.
Ron
Hello Guylain
  You can put this low in priority to be fixed.
  When the partial phase is over I will take how ever many I feel I will need ot fill this requirement.  They will only be a couple of  minutes or so after the plan would have taken them.
  I will be using several camera, each dedicated to a part of the eclipse.  I will move from camera to camera after does it job.  I do need the totality part to be automated and that plan has been working satisfactorily on the table top.  The partial plans will fill in time and be used in the future processing projects.
  Thanks for your attention to this.
Ron
