XCalRocketMan
I've attached two Canon cameras, a 50D and a 70D. Both use USB cables to connect. I have two instances of BYE 3.1.11 running; the master (50D) and the provided slave (Camera 2, 70D). Both cameras connect and both operate from their respective BYE instances. I set Dual Camera on the master instance to connect to localhost:1502 and verify that the Camera 2 instance is, in fact, on 1502. Each camera has a different plan. When I press 'Start Capture' on the master instance the cameras start to image fine, but, the 70D does not follow its plan, but appears to be using the master's plan settings. Number of images, ISO setting and Shutter Speed are mirrored on the slave.
6
Jul 4
10
Jul 5
Aug 4
admin 6 posts
XCalRocketMan 6 posts
astroman133 1 post
Szumi 1 post
Jul 4 2017
Jul 5 2017
Aug 4 2020
13 answers to this question
