PDF Manual
specialk8900
  • Answers 3
3 answers to this question
The User Guide is installed in the BYE/BYN executable directory. I don't use BYN, so can't give you the exact folder path.
If you launch BYN and click on the question mark button in the upper right, the user guide will be launched. Then you can save it to whatever other location you may want.
Hi,
A PDF version of the manual is only available in BYN 2.0 or BYE 3.1.7.  In versions before that is was provided as a .CHM file.
I see from your account that you have BYN 1.0.x.  Please download BYN 2.0 and proceed to install it, the upgrade from 1.0.x to 2.0.x is free and requires no key upgrade, just download and install.
Once BYN 2.0.x installed you will see a PDF file in the install folder as Rick indicated.
Hope this helps,
