ChrisMoses
Hi,
I'm a developer. I just wrote a proxy-system to allow using ascom mounts connected to other machines. Basically ASCOM-over-ip. It lets you run just the drivers and the small proxy program on the (very small) computer at the mount. So fat it seems to work with MaximDL and TheSkyXPro, the only programs I've tried.
I would like to start working on ASCOM cameras next. If BYN/BYE uses ASCOM commands, I would love to play with it. So a few questions
1. Does this sound interesting to anybody?
2. If so, will you ship the driver as a separate install? I can't install BYN/BYE on every machine for the simple reason that I would need some machines without it to make sure it really worked.
If this sounds interesting to anyone, let me know. I know and use BYN and would love to be able to get rid of virtually all usb wire clutter and/or long lines going inside during the winter. Just place a stick computer or NUC computer right on the mount or eyepiece table and run everything to it. From there, the equipment is controlled remotely over wi, on computers running the reall programs. No need for larger computers that can support VPN/RAS solutions.
Thanks
3 answers to this question
