Poss 3.1.6 problem when using Astrotortilla
cstachon
Hi,
Have just updated to 3.1.6 but have started to have funnies when using Astrotortilla.
The problem appears to be 2 fold - one may be how Astrotortilla works but the other is BYEOS problem (i think).
It all stared after the upgrade to 3.1.6(doesn't it always!) and is described as follows:-
Setup  system as normal pressed Capture and solve status line in Astrotortilla(AT for short - too long to keep typing) says camera error. Checked all the most obvious - was BYEOS using 1499 and 127.0.0.1 etc yep no problem. So restarted BYEOS and AT tried again same thing status line "camera error" - tried with log viewer just said "traceback" gave up as I wanted to do some Astro viewing.
Today during daylight I connected camera to same PC only with short USB cable in case there was a problem with the long one I was using. It ran - must be the cable right - wrong. I decided to mark the pictures in Backeos as deleted and tried again - sure enough camera error as per last night. OK I thought seems reasonable you cant deleted pictures taken by BYEOS if you are using AT. Wrong if if tried to do a capture and solve again it started working so I dug a little deeper. It seems when using AT with BACKEOS 3.1.6 (didn't seem to be a problem in 3.1.5) AT is getting BACKEOS to take a picture but is using the picture taken before - i.e. not the latest. If you look in the log the filenames dont match (time wise) so for example AT would asked BACKEOS to take a pic which it does and calls it 12.30.44(missed date etc off) but the log in AT shows it is using 12.28.22 which was the picture before. Strange eh!
Now I am sorry but I also use APT so I tried the same set up with APT instead of BACKEOS - this used the correct picture each time - not out of step as it seems BACKEOS/AT did.
It would also appear the AT is not waiting or is getting told the camera has took the picture and downloaded it when BACKEOS is in the process of taking the picture !!!
Here is the log attached of my test today - it contains both the BACKEOS and APT attempts - backeos uses preview in name.
AT is version 0.7BACKEOS problem 25april 2016.txt
  • Answers 5
5 answers to this question
Hi,
AT is version 0.7attachicon.gifBACKEOS problem 25april 2016.txt
below  log  after clean restart may help - not sure if the binning failure is a red herring.
2016-04-26 13:27:57,454 - astrotortilla - INFO - Failed to set 'binning' to '1' for 'Camera-ByEosCamera'
2016-04-26 13:28:20,937 - astrotortilla - INFO - Connecting to camera...
2016-04-26 13:28:20,937 - astrotortilla - INFO - Exposing: 10.00 seconds
2016-04-26 13:28:21,405 - astrotortilla - INFO - Exposing: 9.8 seconds
2016-04-26 13:28:21,904 - astrotortilla - INFO - Exposing: 9.3 seconds
2016-04-26 13:28:22,404 - astrotortilla - INFO - Exposing: 8.8 seconds
2016-04-26 13:28:22,903 - astrotortilla - INFO - Exposing: 8.3 seconds
2016-04-26 13:28:23,403 - astrotortilla - INFO - Exposing: 7.8 seconds
2016-04-26 13:28:23,901 - astrotortilla - INFO - Exposing: 7.3 seconds
2016-04-26 13:28:24,401 - astrotortilla - INFO - Exposing: 6.8 seconds
2016-04-26 13:28:24,900 - astrotortilla - INFO - Exposing: 6.3 seconds
2016-04-26 13:28:25,398 - astrotortilla - INFO - Exposing: 5.8 seconds
2016-04-26 13:28:25,898 - astrotortilla - INFO - Exposing: 5.3 seconds
2016-04-26 13:28:26,398 - astrotortilla - INFO - Exposing: 4.8 seconds
2016-04-26 13:28:26,897 - astrotortilla - INFO - Exposing: 4.3 seconds
2016-04-26 13:28:27,395 - astrotortilla - INFO - Exposing: 3.8 seconds
2016-04-26 13:28:27,894 - astrotortilla - INFO - Exposing: 3.3 seconds
2016-04-26 13:28:28,394 - astrotortilla - INFO - Exposing: 2.8 seconds
2016-04-26 13:28:28,894 - astrotortilla - INFO - Exposing: 2.3 seconds
2016-04-26 13:28:29,392 - astrotortilla - INFO - Exposing: 1.8 seconds
2016-04-26 13:28:29,891 - astrotortilla - INFO - Exposing: 1.3 seconds
2016-04-26 13:28:30,391 - astrotortilla - INFO - Exposing: 0.8 seconds
2016-04-26 13:28:30,891 - astrotortilla - INFO - Exposing: 0.3 seconds
2016-04-26 13:28:31,888 - astrotortilla - INFO - Waiting for camera
2016-04-26 13:28:32,388 - astrotortilla - INFO - Waiting for camera
2016-04-26 13:28:32,888 - astrotortilla - INFO - Waiting for camera
2016-04-26 13:28:33,388 - astrotortilla - INFO - Waiting for camera
2016-04-26 13:28:33,888 - astrotortilla - INFO - Waiting for camera
2016-04-26 13:28:34,387 - astrotortilla - INFO - Waiting for camera
2016-04-26 13:28:34,901 - astrotortilla - INFO - Waiting for camera
2016-04-26 13:28:35,401 - astrotortilla - INFO - Waiting for camera
2016-04-26 13:28:35,900 - astrotortilla - INFO - Waiting for camera
2016-04-26 13:28:36,398 - astrotortilla - INFO - Waiting for camera
2016-04-26 13:28:36,898 - astrotortilla - INFO - Waiting for camera
2016-04-26 13:28:37,398 - astrotortilla - INFO - Waiting for camera
2016-04-26 13:28:37,913 - astrotortilla - INFO - Waiting for camera
2016-04-26 13:28:38,161 - astrotortilla - INFO - Waiting for camera
2016-04-26 13:28:38,740 - astrotortilla - INFO - Waiting for camera
2016-04-26 13:28:39,334 - astrotortilla - INFO - Waiting for camera
2016-04-26 13:28:39,832 - astrotortilla - INFO - Waiting for camera
2016-04-26 13:28:40,332 - astrotortilla - INFO - Waiting for camera
2016-04-26 13:28:40,832 - astrotortilla - INFO - Waiting for camera
2016-04-26 13:28:41,331 - astrotortilla - INFO - Waiting for camera
2016-04-26 13:28:41,845 - astrotortilla - INFO - Waiting for camera
2016-04-26 13:28:42,375 - astrotortilla - INFO - Reading image from camera
2016-04-26 13:28:42,609 - astrotortilla - INFO - Solving...
2016-04-26 13:28:44,622 - astrotortilla - INFO - Reading input file 1 of 1: "/cygdrive/c/users/cstachon/appdata/local/temp/camemt6cw/PREVIEW_20160426-13h28m24s027ms.JPG"...
2016-04-26 13:28:45,855 - astrotortilla - INFO - jpegtopnm: WRITING PPM FILE
2016-04-26 13:28:47,601 - astrotortilla - INFO - Read file stdin: 5184 x 3456 pixels x 1 color(s); maxval 255
2016-04-26 13:28:47,710 - astrotortilla - INFO - Using 8-bit output
2016-04-26 13:28:57,227 - astrotortilla - INFO - Extracting sources...
2016-04-26 13:29:02,595 - astrotortilla - INFO - simplexy: found 1 sources.
2016-04-26 13:29:05,378 - astrotortilla - INFO - Solving...
2016-04-26 13:29:05,813 - astrotortilla - INFO - Reading file "/cygdrive/c/users/cstachon/appdata/local/temp/solver8xirbc/9/PREVIEW_20160426-13h28m24s027ms.axy"...
2016-04-26 13:29:05,924 - astrotortilla - INFO - Only searching for solutions within 25 degrees of RA,Dec (42.6689,89.3316)
2016-04-26 13:29:06,048 - astrotortilla - INFO - Field 1 did not solve (index index-4112.fits, field objects 1-10).
2016-04-26 13:29:06,157 - astrotortilla - INFO - Field 1 did not solve (index index-4111.fits, field objects 1-10).
2016-04-26 13:29:06,266 - astrotortilla - INFO - Field 1 did not solve (index index-4110.fits, field objects 1-10).
2016-04-26 13:29:06,375 - astrotortilla - INFO - Field 1 did not solve (index index-4109.fits, field objects 1-10).
2016-04-26 13:29:06,484 - astrotortilla - INFO - Field 1 did not solve (index index-4108.fits, field objects 1-10).
2016-04-26 13:29:06,594 - astrotortilla - INFO - Field 1 did not solve (index index-4107.fits, field objects 1-10).
2016-04-26 13:29:06,703 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:06,828 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:06,937 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:07,046 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:07,171 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:07,280 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:07,390 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:07,499 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:07,608 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:07,888 - astrotortilla - INFO - Did not solve (or no WCS file was written).
2016-04-26 13:29:07,888 - astrotortilla - INFO - Field: /cygdrive/c/users/cstachon/appdata/local/temp/camemt6cw/PREVIEW_20160426-13h28m24s027ms.JPG
2016-04-26 13:29:07,904 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:07,920 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:07,936 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:07,951 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:07,967 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:07,983 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:07,997 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,013 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,029 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,045 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,061 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,075 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,092 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,108 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,122 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,138 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,154 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,170 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,186 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,200 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,217 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,232 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,247 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,263 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,279 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,295 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,309 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,325 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,342 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,357 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,372 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,388 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,404 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,420 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,434 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,450 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,466 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,482 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,497 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,513 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,529 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,543 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,559 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,575 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,591 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:29:08,607 - astrotortilla - INFO - No solution in 26.0s
2016-04-26 13:29:31,213 - astrotortilla - INFO - Connecting to camera...
2016-04-26 13:29:31,229 - astrotortilla - INFO - Exposing: 10.00 seconds
2016-04-26 13:29:31,775 - astrotortilla - INFO - Reading image from camera       didn't wait for camera!!!!!!!!!!!!!!!!!!!!!!!!
2016-04-26 13:29:32,009 - astrotortilla - INFO - Solving...
2016-04-26 13:29:33,430 - astrotortilla - INFO - Reading input file 1 of 1: "/cygdrive/c/users/cstachon/appdata/local/temp/camemt6cw/PREVIEW_20160426-13h28m24s027ms.JPG"...
2016-04-26 13:29:34,648 - astrotortilla - INFO - jpegtopnm: WRITING PPM FILE
2016-04-26 13:29:36,723 - astrotortilla - INFO - Read file stdin: 5184 x 3456 pixels x 1 color(s); maxval 255
2016-04-26 13:29:36,832 - astrotortilla - INFO - Using 8-bit output
2016-04-26 13:29:46,177 - astrotortilla - INFO - Extracting sources...
2016-04-26 13:29:54,446 - astrotortilla - INFO - simplexy: found 1 sources.
2016-04-26 13:30:00,427 - astrotortilla - INFO - Solving...
2016-04-26 13:30:01,565 - astrotortilla - INFO - Reading file "/cygdrive/c/users/cstachon/appdata/local/temp/solver8xirbc/10/PREVIEW_20160426-13h28m24s027ms.axy"...
2016-04-26 13:30:01,690 - astrotortilla - INFO - Only searching for solutions within 25 degrees of RA,Dec (42.6697,89.3316)
2016-04-26 13:30:01,908 - astrotortilla - INFO - Field 1 did not solve (index index-4112.fits, field objects 1-10).
2016-04-26 13:30:02,345 - astrotortilla - INFO - Field 1 did not solve (index index-4111.fits, field objects 1-10).
2016-04-26 13:30:02,470 - astrotortilla - INFO - Field 1 did not solve (index index-4110.fits, field objects 1-10).
2016-04-26 13:30:02,595 - astrotortilla - INFO - Field 1 did not solve (index index-4109.fits, field objects 1-10).
2016-04-26 13:30:02,720 - astrotortilla - INFO - Field 1 did not solve (index index-4108.fits, field objects 1-10).
2016-04-26 13:30:02,845 - astrotortilla - INFO - Field 1 did not solve (index index-4107.fits, field objects 1-10).
2016-04-26 13:30:02,970 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:03,095 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:03,221 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:03,331 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:03,456 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:03,581 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:03,690 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:03,815 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:04,016 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:04,141 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:04,250 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:04,375 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:04,500 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:04,609 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:04,734 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:04,875 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:05,000 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:05,108 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:05,219 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:05,342 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:05,453 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:05,562 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:05,717 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:05,842 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:05,967 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,076 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,450 - astrotortilla - INFO - Did not solve (or no WCS file was written).
2016-04-26 13:30:06,450 - astrotortilla - INFO - Field: /cygdrive/c/users/cstachon/appdata/local/temp/camemt6cw/PREVIEW_20160426-13h28m24s027ms.JPG
2016-04-26 13:30:06,467 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,482 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,497 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,513 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,529 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,545 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,559 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,575 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,591 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,607 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,622 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,638 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,654 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,668 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,684 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,700 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,716 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,732 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,746 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,763 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,779 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,809 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,825 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,841 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,857 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,888 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,903 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,918 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,934 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,950 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,966 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,980 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:06,996 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,013 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,028 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,043 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,059 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,075 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,091 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,105 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,137 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,153 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,168 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,184 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,200 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,214 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,230 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,246 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,262 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,278 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,292 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,309 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,325 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,339 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,355 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,371 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,387 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,403 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,417 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,434 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,448 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,464 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,480 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,496 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,512 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,526 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,542 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,559 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,573 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,589 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,605 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,621 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,637 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,651 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,683 - astrotortilla - INFO - Field 1 did not solve.
2016-04-26 13:30:07,698 - astrotortilla - INFO - No solution in 35.7s
If AT is solving the previous picture that would make it tough for it to work!
If I remember correctly, the way that the external API works is that AT polls BYE to see if the image is ready/available.  When the image is ready then AT asks for the file name. Then AT copies the file into its folder and starts the solving process.  I can see where a problem could creep into that process.
BTW, BackyardEOS is typically abbreviated as BYE, not BACKEOS.
There were some changes to the API used by AstroTortilla in both BYE releases 3.1.5 and 3.1.6. Can you please confirm that the previous version that did work was 3.1.5? Having that info will make it easier for Guylain to troubleshoot.
Thanks,
This is the bug, thank you for reporting this.  I'll try find the root cause and fix it.
Ok tried it on 3.1.1 version of BYE (sorry old age BackEOS!) and it seems to do the same but I must have not noticed it because it didn't come up with the "camera error" as I probably didn't delete the pictures. Always wondered why some solves failed then worked !!!!!!!!!! Thanks for looking into the problem I can use the Open File dialogue or just take a picture twice for now. If I get a chance I will test 3.1.6 again in Windows 10 as this was in Windows Vista. Must have updated my test bed to 3.1.6 so haven't got a 3.1.5. Plus if it helps NETSTAT showed the port 1499 listening before I loaded AT which I would expect.
