1DegreeN
When dithering via PHD2, BYEOS waits for around 90 seconds for PHD2 to report that the guide star has returned to within the settle distance from the lock position. Is this 90 second timeout set by BYEOS and could it be made a configurable parameter via Settings?
I am using an Astrotrac mount which only guides in RA. I'm using PHD2's drift alignment to try to get the best Polar Alignment I can but even a tiny PA error results in Dec drift that accumulates over the session and of course can't be guided out. When PHD2 dithers and it reports the distance from the lock position back to BYEOS, it is the absolute dec drift from the start of the guiding session that is measured and not the relative dec drift before and after dithering. Even though the dec drift during each sub is small and my subs have nice round stars, after a few subs the absolute dec drift has grown to the point where PHD2 will never report a small enough settle distance to trigger BYEOS to begin the next sub - and then I have to wait for the 90 second timeout to elapse.
I do have a manual workaround: about 15 seconds before the end of a sub I switch to PHD2 and quickly stop guiding, auto-select the guidestar again and resume guiding - this resets the lock position. My experience so far shows that my Astrotrac mount typically takes 15-30 seconds for RA to return to lock after dithering; if the timeout could be configured then I would set it to around 30 seconds.
Thanks!
John
