NightBikes
I'm using ASCOM Device Hub with the following connected: Explore Scientific EXOS2-gt PMC 8 Mount, Stellarium, BYN, and PHD2. Occasionally, when I click center in BYN on my target, ASCOM locks/freezes up. It only happens when centering. However, I can go multiple imaging sessions without any issue, and have other nights where it repeats several times. My only fix is to force shutdown my computer and restart everything. I think I've copied the relevant log info below. Firewall is turned off. Suggestions on what to check? Thank you!!
2023-10-15 22:47:08,566 [17] ERROR - CheckDotNetExceptions ASCOM.DeviceHub.Telescope SlewToTarget System.Exception: Unable to start the slew to target!!! (See Inner Exception for details)
2023-10-15 22:47:08,566 [17] ERROR - at ASCOM.DriverAccess.MemberFactory.CheckDotNetExceptions(String memberName, Exception e) in C:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 629
at ASCOM.DriverAccess.MemberFactory.MethodTargetInvocationExceptionHandler(String memberName, Exception e) in C:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 677
at ASCOM.DriverAccess.MemberFactory.CallMember(Int32 memberCode, String memberName, Type[] parameterTypes, Object[] parms) in C:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 486
at ASCOM.DriverAccess.Telescope.SlewToTarget() in C:\ASCOM Build\Export\ASCOM.DriverAccess\Telescope.cs:line 1062
at BinaryRivers.ASCOM.Platform60.TelescopeASCOM.SlewToTarget(Coordinate coordinate, Boolean setTracking)
2023-10-15 22:47:08,566 [17] ERROR - Unable to start the slew to target!!!
2023-10-15 22:47:08,566 [17] INFO - Telescope DeviceHub -> Explore Scientific PMC-Eight ASCOM Driver current properties.
2023-10-15 22:47:08,566 [17] INFO - +--- Epoch : JNOW
2023-10-15 22:47:08,566 [17] INFO - +--- RightAscension : 21.669883003418 : 21h40m12s
2023-10-15 22:47:08,566 [17] INFO - +--- Declination : 57.775260416667 : 57 46'31"
2023-10-15 22:47:08,566 [17] INFO - +--- Altitude : 65.313154424924 : 65 18'47"
2023-10-15 22:47:08,566 [17] INFO - +--- Azimuth : 325.562340616159 : 325 33'44"
2023-10-15 22:47:08,566 [17] INFO - +--- SiteLongitude : -104.8872
2023-10-15 22:47:08,566 [17] INFO - +--- SiteLatitude : 39.76556
2023-10-15 22:47:08,566 [17] INFO - +--- SiteElevation : 1609
2023-10-15 22:47:08,566 [17] INFO - +--- IsParked : False
2023-10-15 22:47:08,566 [17] INFO - +--- IsHome : False
2023-10-15 22:47:08,566 [17] INFO - +--- IsTracking : True
Oct 17
Oct 18
NightBikes 2 posts
astroman133 1 post
Oct 17 2023
Oct 18 2023
1 post
astroman133
You should look at the PMC-8 driver logs for the cause of the error. DeviceHub is reporting a problem to BYE that originated in the PMC-8 driver.
