Setting ISO to 50 ("L")
Bill.Richards
My Canon 6D Mk 2 has a low ISO setting ("L") that is equivalent of ISO 50, but I cannot select that setting within BYE; it only goes as low as ISO 100.  Is there some way to do this?  If not, is that something that can be added to BYE?
  • Answers 4
ISO values are cached, and the cache is created the first time it reads them from the camera. If the camera settings at the time were such that L was not there, BYE won't show it.
This said, you can go to Settings -> Advance Settings and clear the cache. BYE will rebuild it. Worth a try.
Awesome - thanks!  The "L" setting was disabled the first time I connected the camera and did not appear once I enabled it, so this makes sense.  I will give your suggestiona try.
