geoffoto
I have a NIKON D800 capturing onto an older HP laptop with WinXP. I set BYN to 10 exposures and the camera shutter releases 10 times and appears to download each between frames. The problem is only two frames are actually captured. The camera as well as the BYN display both show only two frames.
Is this possibly because of the older OS? I have plenty of hard drive space (17GB).
I'll add that the above was a test with small files. In the field, with larger files, the laptop DRAGS during download and actually quits - the 10-frame sequence never completes - after two frames.
