lietzed
Bought this software in 2017 and updated it and reactivated the key but when I tried to connect the camera I get these 4 messages.
1) Make sure EOS Utility is not running.
Not sure what this means. On the computer or on the camera?
2) Make sure the camera is turned on and the battery is fully charged.
The camera is on and the battery is full charged
3) If you are trying to connect a DIGIC II camera model such as the 5D, 20D, 20Da, 30D, or 350D make sure your are running Windows 32 bits. These models do not work on Windows 64 bits.
How do I check this?
4) If you are using a USB hub, remove it, connect the camera directly in a USB port on your computer and try again.
Not using a hub. Single cable. Also tried another cable with the same result.
If you are still having issues please visit our support forum at http://forum.otelescope.com and open a support ticket.
So here I am. Any suggestion??
Dec 11
Dec 17
Jan 16
Dec 16
astroman133 2 posts
lietzed 2 posts
admin 1 post
Dec 11 2022
Dec 17 2022
1 post
Jan 16 2023
1 post
Dec 16 2022
1 post
astroman133
1) Make sure EOS Utility is not running. The Canon EOS Utility is a Canon camera control program, similar to BYE, but not focused on astrophotography. It if is connected to the camera BYE will no
