Andante_2
Hello,
I've been happily using BYN for two years with a MacBook Air/Windows 10 Home dual boot system. I connect via a cable through a Startech powered hub.
I'm migrating to a stick PC, the MeLe PCG02, which hosts Windows 11 Pro. The driver installs correctly and the camera is found under "Portable Devices" in the Device Manager, as it also is with the MacBook. In both cases I am also able to access the Nikon SD card files (now deleted, of course). However, BYN does not connect to the camera. I get the same null result whether I connect with the known good cable either through my powered hub or directly to a port on the MeLe. Cycling the camera power didn't help either.
Suggestions?
Thanks,
Don
Aug 7
Aug 4
Aug 8
Aug 3
Andante_2 3 posts
admin 2 posts
astroman133 2 posts
s3igell 1 post
Aug 7 2022
Aug 4 2022
Aug 8 2022
1 post
Aug 3 2022
1 post
7 answers to this question
