slickrock
Hi Guylain,
A couple nights ago I tried to image M13 with a Nikon 1 V3 on a 400mm Lens. I was using BYN 2.1.3 RC3 and had set up an imaging run of 140 x 30s images with dithering (ASCOM with an AP Mach2 mount) every 3 images. The imaging run started out good (I had plate solved on M13 and so M13 was centred on the image) and was good for 31 images. The image centre RA was at 16 41 42.945, and DEC was at 36 25 23.75. Then, after a dither, M13 jumped and the image centre was at RA 16 42 05.272 and DEC was at 36 22 00.03. The imaging run continued until the end (another 109 images) all with the image centre at the new RA and DEC. I had gone to bed and let BYN do it's work and when I got up in the morning the mount was nicely parked. Any idea what may have caused this?
I've attached two images, # 304 and #305. 304 shows M13 centred and 305 shows M13 shifted. I've also attached an excerpt of the log file from a dither at image # 302 until the dither just before image # 305.
Thanks,
Terry
BYN-2022-05-07.txt
May 10
10
May 11
admin 2 posts
astroman133 3 posts
slickrock 6 posts
May 10 2022
May 11 2022
1 post
astroman133
The AstroPhysics controller has a Meridian Delay setting that can be set negative or positive to do an early or late flip. The OP would have had to set that value to -2 hours to flip as early as he sa
slickrock
Well, I don't know.... I set up the mount to do some testing today. I pointed the mount to DEC 35 51 04 (pretty close to where it was the other night) and 2h 6m East of the meridian. I let the
10 answers to this question
