D810: Seemingly not able to use Long Exposure NR
hdnathan
As recommended practice in "The Backyard Astronomer's Guide", I've tried to use the LONG EXPOSURE NR > ON menu selection in the Nikon D810 but using this causes BYN to abort the exposure session at the end of the first frame of capture.  Am I doing something wrong, is there a work around or is this feature just not supported at this time.
Thanks,
Nathan
  • Answers 4
Despite the guidance you got from the "The Backyard Astronomer's Guide", most of us DO NOT USE the Camera's built-in Long-Exposure Noise Reduction (LENR) feature.
This is because:
1) We tend to want "More Control" over our Image Processing, including Calibration using Darks / Flats / Bias Frames.  If the Frames are already Dark-Subtracted via LENR, then this is difficult/impossible.
2) We tend to want to make the most of our Imaging Time by capturing JUST the Light Frames, and then capturing the Darks / Flats / Bias Frames later (if we don't already have them stored in Libraries).
That being said...
In general, BYE/BYN should handle LENR Imaging much more Gracefully - by simply spinning the "Downloading" indicator until the LENR Exposure is completed.
(Do make sure that you are using Bulb Mode for your Exposures - not just Manual...)
